A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
Display Backlight not working
Few days ago my macbook pro A1708 was Stage Light Effect on Display Screen & backlight flickering. Now my Display Backlight not working.
I've plan to repair/replace the full display or only LCD screen panel.
Now my question is-
If I replace only LCD screen panel (Attach Pic 1), can it’s resolve all Stage Light Effect, backlight flickering and no Backlight problem?
OR
I replace full display (Attach Pic 2)?
OR
I replace only LVDS LED Display Flex cable (Attach Pic 3)
OR
Do you have any better solution?
Thanks
Updates:
1. With External monitor my Macbook working well.
2. In dark room with high flash light, I can see my Macbook desktop’s icon.
Pic 1
Pic 2
Pic 3
Add a comment
1 Answer
This could be a number of things.
  1. Bad display cable
  2. Bad display
  3. Or damaged backlight cicuit
The fist thing I would do is connect the computer to an external monitor to rule out a video card/gpu issue. Next, shine a flashlight on the screen in a dark room to see if you still have an image on the screen and that the issue is no back light.
After confirming that it is a no back light issue, I would start with replacing the display cable this will be the least expensive solution. If that doesn’t work try the new display. Finally, if the new cable and new display do not fix the issue either replace or repair your logic board.
Add a comment
Add your answer
Imam Hossain will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,396
