The Coolpix P530 is a 16.1 megapixel digital camera with an impressive 42x optical zoom. This model was released by Nikon in February of 2014. It also goes by the manufacturer specific model name Nikon 26464 .
20 Questions View all
camera nikon coolpix p520 does not turn on
change battery and it does not work
Score 1
Add a comment
First check the battery. Is it charged? Is it healthy or old and dead? If the battery is OK take the camera to a service facility; you cannot fix the insides of cameras, unless you are a trained camera technician.
1 Comment:
Known problem... hundreds have the same problem with this camera... no known solving issue.. looking for an answer all over the internet... Even Nikon doesn't want to fix... new battery, received today... impossible to turn on camera
by
Add a comment
Talked to a Nikon repair guy: his simple answer … “it’s a contact issue” meaning the problem can be most likely solved with a soldering iron, reworking solder points one by one…
Add a comment
Add your answer
henryfiold will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 36
All Time: 3,379
