Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1959 Questions View all
one headphone is not working...
3gs 32gb have changed the 3 times powerflex but still same problem only 1 headphone is working other not. but when we take out the flex out to phone and we adjusting the headphone cable rarely i can listen both headphones are working. with the orignal flex also same problem. i already checked the logic board with the other phone . logic board is ok
Comments:
SIMRAN, have you checked your headphones and may be tried another one?
by
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
i have a set of bose headphones that only work at a certain position in the iphone... no matter which phone they are in.. I believe it is a problem with the jack pin on the headphones. I'd try the advice and try other headphones
Score 3
Comments:
Simran if you are happy the logic board is ok, and you are sure the headphones are ok then it only leaves one thing that can be defective. It would be highly unlikely that 3 power flex are also defective unless you are buying from the same dealer.. ?? perhaps it is not connected properly?
by
i bought all from the same seller. now what to do. if we take out the flex from the phone use again then at certain point both headphone are working .
by
simran..if you bought 1 from the same seller and sent it back, then got another 2 faulty flex I think really you have a batch of bad flex. don't buy there again!!!! buy from another dealer, use ebay whatever, but get a refund...
by
Add a comment
If one headphone is playing and the other is not, you probably just need to get new headphones. You're plugging the headphones directly into the phone, correct? Because if you are using some sort of adapter, you may have the wrong one.
Comments:
i m using the orignal came with this . that are working fine with my macbook pro and ipod ...
by
Add a comment
You could try using a different pair and see if they work.
Comments:
i tried but no success ....
by
Add a comment
Add your answer
SIMRAN will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,564
