4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Questions View all
Name of this component for iPhone SE?
Hello, which is the name of this component for iPhone SE? First time with my broke iPhone when I tried to replace motherboard, this component has been removed from iPhone. Which is the function of this component? And is possible repair it with a something as the welder? Because I noticed it is attached to iPhone.
Image of component:
Thank you in advance for reply.
1 Comment
Add a comment
Chosen Solution
That’s a teared off part of the wifi/bluetooth antenna. It’s a pretty inexpensive part but you’ll have to buy a new one. No need for soldering, it’s simply glued to the housing.
Score 4
2 Comments:
@refectio That's where it was hidden, thanks for the addition =:)
by
Add a comment
That’s part of the rear case. You can see it in this photo from the teardown, and this one too.
To get WiFi/cellular connection, you’ll need to buy a new rear case, since the connector is permanently attached to it, and can only come off if the cable is torn. It looks like you can relatively easily get new (though not necessarily OEM) cases on eBay.
2 Comments:
No, there's no need to replace the housing, it's sufficient to buy the new antenna and replace the part of the old one left, some warming makes the job easier.
by
Oh, I had no idea that it wasn't part of the rear case!
That's nice to know. Thanks for clearing that up!
by
Add a comment
Add your answer
Patrizio Masini will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 80
