LTE-enabled variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
46 Questions View all
Apple Logo shows for 5 seconds then shuts off after digitizer change
I changed the display, home button, and rear camera on an iPad 5 and now when I turn it on, the Apple logo comes on for 5 seconds then goes away and only the backlight stays on.
I have taken the device back apart several times to make sure that all the connections are clean and properly plugged in, but it still acts like this.
What am I missing or where do I go from here?
Everything worked good on it when it was brought to me, minus the digitizer being broken..
Thank you.
2 Comments:
What happens when you use the original digitizer?
by
That is not an option since the original is in about 1,000 pieces.
by
Add a comment
1 Answer
I suspect you have received a faulty or low quality digitizer. I would try another digitizer just to be 110% sure. If a new digitizer doesn’t fix anything; I suspect it’s a Logic Board issue.
iPad 5 Screen Digitizer
iPad 5 LTE Front Panel Assembly Replacement
iPad 5 Screen Digitizer Image
Product
$44.99
1 Comment:
I will throw a different digitizer on tonight when I get off work.
Thank you.
by
Add a comment
Add your answer
sunruh will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 75
