Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1952 Questions View all
iPhone wont charge or connect to itunes or computer or wall.
Ok i have a little problem with my iPhone 3gs. At first my screen broke so i ordered a new one and put it in, and my phone worked just fine for about 2 days. Then it stopped charging with my wall charger. At first i thought it was just the charger cable. So i hooked it up to my car charger and it worked for about 10 minutes and stopped again. I then tried multiple chargers and ways of charging and none would work. So i figured it must be the charging components inside the phone so i ordered a new one along with a new battery just in case. I replaced both and plugged it into my computer, and it popped up and said it was installing the driver and said an iPhone had been found. Then within 10 seconds it disappeared. Then i was holding my phone and squeezed the sides a little and it started again. So there is the problem. There is some kind of connecter or something that’s not doing something right for it to charge or do anything via the charging port. I have looked all over the internet for different posts or anything relating to it and i have found nothing at all. Any help would be great! Hopefully someone has had a similar problem and found how to fix it. Thanks in advance!
Comments:
now it says "itunes could not connnect to the iphone "" because an invalid response was received from the device"
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Check the Logic Board on the right side over the battery area, make sure the screws there are nice and tight, don't strip anything, and also check Connector #4 to be certain it is set correctly on the Logic Board. Turn iPhone OFF before you open it up.
Score 2
Comments:
i checked all of that. and it still has no change. thanks tho
by
also check the battery prongs arent flattened, use a multimeter to check the battery is charged.(or try old battery) clean all your connections for dock and battery.
by
ok will try that n c if it helps
by
Add a comment
any luck?
Comments:
nope none. at all. the new battery i got died too. so im back to square one
by
Add a comment
Add your answer
james will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 4,624
