Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1501 Questions View all
Replaced LCD and phone worked but ear, checked cables now no power
I have an iPhone 3G that had a shattered screen and LCD. I bought replacement parts and did the repair. Everything seemed to be working until I made a phone call and could not hear from the ear piece, only sound would come when put into speaker mode. I read that maybe connector 3 was not fully seated so I went back inside the phone and tried to re-position the connector, now the phone will not turn on. I plugged it in and even after awhile of "charging" it would not even vibrate when the switch was moved. Does anyone know what may have happened, and what I can do?
Add a comment
1 Answer
Chosen Solution
check all your connections.. you may have dislodged the power flex (no. 5 or 6... the square shaped connection in the top left of your board) or the display isn't connected so you need to check 1+2, give them a firm press or they tend to pop off when you close up the display.
Score 3
Add a comment
Add your answer
Brandon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 703
