MBP won't turn on/boot up
MacBook Pro 17" Model A1261
Having the same problem as other post "MBP won't turn on/boot up" . MBP was working fine, closed lid, couple hours later opened lid, unit would not turn on. I bought it used about a year ago and it has worked fine and nothing has been changed.
Power cord light is green, battery has full charge. When power button is pushed, LED light turns on for about 3 seconds, then turns off. If power button is held down, LED light stays on for about 6 seconds, flashes a number of times , then goes off. The DVD clicks a number of times and the fans turn on during this time.
I tried disconnecting the power and battery and holding the power button for 30 sec, reconnecting power-no change, PRAM reset- no change, disconnected the hard drive and DVD with no change, LED light still only comes on for a few seconds,unit will not turn on. Any suggestions what to check next? Bad logic board?
