left mouse click doesn't work
left mouse click doesn’t work, I have tried several new mice to see if it was the mouse itself but none of them worked
Could you please provide some more information on what type of mouse you are using? If the mouse you are attempting to use is a mouse made by Apple there may be a setting that we need to change in order for it to work.
First of all, to address your non-functioning trackpad we can totally fix that issue for about 65$ total if you do not buy a trackpad that is new nor has the mounting screws (screws are only needed if there are lost or damaged screws). You can replace the trackpad with the guide and part below, it is not that hard!
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpad
MacBook Pro 13" Unibody Mid 2010 Trackpad Replacement
To address the left click on the mice not working, you may be encountering an issue with macOS. I would back up all of your personal data onto an external drive and try a new installation of macOS to rule out a software problem.
It was an off brand. The track pad hasn't worked in a long time but the mouse was working until recently. Just the left button won't work. Any thoughts?
@deback I updated my answer, with a guide on how to replace your non-functioning trackpad too. :-)
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 8
All Time: 93
