Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
1199 Questions View all
iPhone X Front Camera Module Flex Transfer
I accidentally ripped a flex on the front camera module. I managed to get the flex unsoldered from the sensor. I plan to order a new front camera module and transfer the flex from it. I don't know if it's been done or attempted, but wish me luck.
1 Comment
I wish you the best of luck with the repair! I believe this might be possible but time will tell if it actually is.
by
Add a comment
1 Answer
Chosen Solution
Use low heat and don’t overdo it with the flux as you don’t want it going into the actual camera. I would also practice on a few dead flexes (from less expensive parts) if you haven’t worked on flexes before.
Score 3
Add a comment
Add your answer
Brandon Desselle will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 226
