Repair guides and support for a wide range of clocks.
18 Questions View all
Display Screen Electrical Connections
Attached is a picture of the display screen for a Brookstone clock. A ribbon cable was attached to the black pads shown in the picture apparently by either electrical conducting glue or something in the ribbon cable covering works as glue when heated? The second part of the question is I see not electrical leads from the pads into the screen. How does such a system work?
Add a comment
1 Answer
Chosen Solution
Look at it vary carefully with the light at different angles and you should see very faint almost completely transparent conducting tracks. There’s a picture of a calculator display showing the tracks at https://wiki.restarters.net/Connectors#E...
Score 2
Add a comment
Add your answer
Carroll Stroh will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 12
All Time: 76
