Screen is black - can I repair or replace
I have an early 2008 17 inch MacBook Pro with the 1920x1200 Matte Screen. The display is black but the system works fine with an external monitor. Could I just replace the screen or does the screen assembly need to be replaced? I had the spotlights problem for several years on this system which I assume was the fluorescent backlight.
2 Comments
@movdqa describe this "the spotlights problem" a bit more.
by oldturkey03
It was bright at the bottom of the screen with round things and the screen was dimmer as you moved to the top. I was able to use it in this mode for a few years. I think that it was common with this model as I've seen other reports of it.
by Michael Moy
