Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
Why can't I hear other callers but they can hear me fine?
When in a call can’t hear other person. Can hear on loudspeaker, headset, Bluetooth. Earpiece speaker works fine tested it. Tried another front camera flex no luck. Tried apply pressing near front camera no luck. It’s Not stuck in headset mode. Done resets, Updates, Bluetooth on/off, Aeroplane mode on/off still no luck!!…Anyone having same issue on the 6S Plus or anyone have a FIX?
Add a comment
Chosen Solution
If the ear speaker works fine during your tests, then it’s not a hardware failure. Try hard resetting your phone (Home & Power Button for 10 secs) or if that doesn’t work, the go to Settings/General/Reset/Reset All Settings.
Score 2
1 Comment:
Isn’t the earpiece speaker line different from the loud speaker line for audio input? Correct me if I’m wrong but I’m fairly certain he could also have a bad circuit on the earpiece line as the loudspeaker work on separate circuits
by
Add a comment
Did you try to replace earpiece speaker, i had that same issue not on exact iphone. it was iphone 7 i just replaced the earpiece speaker.
Add a comment
Add your answer
Shok will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 108
