Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
Problems attaching the digitizer and LCD screen to the logic board
Hello,
I’m replacing the digitizer and LCD screen on my iPad Air 2 wifi. It seems I can’t get a solid connection when I attempt to reconnect the display and data connectors. It initially worked, but when I had to solve a problem elsewhere, it lost contact.
Initially, the backlight worked, but now, nothing works. No obvious bent pins or other issues — everything appears nominal.
Any advice? Thank in advance for the help.
Add a comment
1 Answer
Try restarting the ipad with the 2 buttons (home and power button) sometimes when messing with the ipad 2 if the ipad is left on and u mess with the connector it doesn't work properly till you restart the ipad
Failing that try squeezing on the black cable from board to lcd or replacing that cable :)
Obviously also check you haven't damaged the power button flex cable if you have then obviously power on and restart won't work :)
Add a comment
Add your answer
nprovenzo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 108
