iPhone won't turn on after battery replacement.
My iPhone won't turn on after battery replacement. I have looked many places and tried many things.
Story:
My iPhone broke so we bought a cheap one from online, took the phone apart and put the battery following a guide exactly except I mixed up the battery casing and screen connector casing screws so I sorted those out as best I could and put it back together. Nothing, screen didn't work, couldn't get any response from the vibrator, after a long charge same thing, except I did feel the phone warm while it charged. Thought it was a defective battery and bought a good one from iFixIt. Replaced it and was extra carful to make sure this time was errorless Put it back together, screen didn't turn on again, same issue. Charged for a couple hours, nothing didn't even warm up the phone, no iTunes response either.
Facts I’m pretty sure of:
- Battery is ok (came from iFixIt)
- Battery to charging port is ok (First battery warmed the phone (second battery was probably full))
- Screen is possibly not broken (Not getting a response from anything not even the vibration so that doesn't mean it's just the screen)
Things I've already tried:
- Quadruple check that all cables connectors are securely in place.
- Let it charge for a while
- Pressing Power and Home buttons for 10+ seconds, and home for 3 then
- Tried unplugging battery and plugging into iTunes
- Tried disconnecting the battery and reconnecting
Not tried:
- Screen replacement
- 3rd battery
- Any other motherboard part replacements
Any and all suggestions appreciated!
Problem found!
It was the screen, I must have damaged it while replacing the battery.
2 Comments
Can you plug it into a computer and see if anything shows up? That might help diagnose if this is a screen issue or a battery issue.
by smartin
I plugged it in with 0 response, no sounds or anything.
by Matthew Vine
