iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
How do I know if I need to replace the LCD?
I bought the iPad Air Front Glass/Digitizer Touch Panel Full Assembly kit. The screen glass is shattered and the touch screen does not work. How do I know if I need to replace the LCD as well? I’m asking because when I was searching for the guide, I saw a separate guide for LCD replacement.
Update (10/09/2018)
Here is an image of my iPad. I'm just not sure what additional parts I now need to order if I have already bought the Front Glass/Digitizer Touch Panel Full Assembly kit assuming I also still need this kit.
Add a comment
1 Answer
Chosen Solution
LCD would need to be replaced as well if you see display artifacting on the screen such as:
  • Horizontal or Vertical lines appearing on the screen.
  • Black splotches on the screen.
  • Ghosting effect on text / graphics on the display.
If it looks fine then it’s just the digitizer touch screen glass needing replacement.
Score 3
3 Comments:
by
You do still need this kit to do the digitizer front glass replacement on a iPad Air. The LCD which is the display under the glass needs to be replaced as well so you'll need to order this too:
iPad Air LCD
by
Are you sure this LCD needs replacing?
<just kidding>
by
Add a comment
Add your answer
Jeanine will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 787
