The Canon EOS Rebel T3i, released in March 2011, can be identified by its SKU (SKU:5169BO32). Also known as the EOS 600D and the EOS Kiss X5, this camera is a Canon Digital SLR with 18 megapixels.
error message "card's write protect switch is set to lock"
when turning on the camera with memory card inserted, i got this message
"card's write protect switch is set to lock" although the card is not lock, tried different card and samething. when i took the card out, it reconized there’s no card and reinsert again, the message come out.
cant take no with push on the shutter button
Score 2
1 Comment
Have you found the solution? I have just incurred the same issue
by
Add a comment
1 Answer
Most Helpful Answer
Hi!
Can you make sure that your card is indeed not write protected? Check the position of the switch on the card:
https://i.ytimg.com/vi/1YPSfvaZceI/maxre...
Score 1
Add a comment
Add your answer
simonleongkm will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 15
All Time: 1,072
