Shop the Holiday Gift Guide
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
Getting error code 4013 after batt & screen replacement
Hi
I’ve replaced my battery and screen on my iphone 6s. Im not getting the looping logo booting screen.
Tried updating to reinstall the OS, no luck. Also tried complete restore also no luck.
Ive unseated all the connectors and put everything back together 3 times now and same issue.
Any one have any idea on what else I can try or am I out of luck?
Score 1
Add a comment
1 Answer
Most Helpful Answer
Tunes error 4013/4014 (also called iPhone error 4013, iPhone error 4014) is a hardware related error which are mostly seen due to faulty cable or faulty port. To put it simply, the error is actually due to problems in connectivity between you PC / Mac and iDevice.
When you connect your iOS device to computer, although the device was recognized by the computer and there seem to be no loss of connection apparently but there are some faulty cables that hinder the transfer of data.
UPDATE
This link gives eight possible solutions to the 4014 error code:
https://drfone.wondershare.com/iphone-pr...
  • Part 1: What is iPhone Error 4013 (iTunes Error 4013)?
  • Solution 1: Fix iPhone error 4013 or iTunes error 4013 without losing data
  • Solution 2: Fix iTunes error 4013 by checking USB port & connector
  • Solution 3: Fix iTunes error 4013 by updating iTunes
  • Solution 4: Fix iPhone error 4013 by resetting all settings
  • Solution 5: Fix iPhone error 4013 or iTunes error 4013 by clearing up space
  • Solution 6: Fix iPhone error 4013 or iTunes 3014 via factory reset
  • Solution 7: Fix iPhone error 4013 by entering DFU mode
  • Solution 8: How to restore iPhone from backups without iTunes?
Score 2
1 Comment:
I had read about that so I tried it with a different cable and got the same result. Short of trying a different computer and cable (Which I will), is there anythign else it could be?
by Share
Add a comment
Add your answer
robert brennan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 2,575
