2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
774 Questions View all
[EN/FR] Keyboard not working / Touche de clavier non fonctionnelle
Hi, my R on my keyboard is not working anymore. Is it possible to acces under the keyboard to clean it ?
Bonjour, ma touche R de clavier ne fonctionne plus, on dirai que quelque chose est coincé dessous. Est-il possible d’accéder sous le clavier pour le nettoyer ?
Add a comment
Chosen Solution
@danj I've seen your answer concerning the z Key ("z" Key not working, Command key also) would you say the procedure is the same here or do you know if there's an option to get below the keys?
Score 1
1 Comment:
Hi Sandra! - Sadly, it's the same! Only difference will likely be the keyboard mapping if Sunny is using a French keyboard.
Sunny - You maybe able to get this fixed under warranty if you bought it less than two years as the EU warranty is two years.
Do keep in mind any liquid spill will void the warranty.
by
Add a comment
Thanks for your answer !
Add a comment
Add your answer
Sunny will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 231
