2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
Sound Distortion and cracking
My MacBook pro and the left speaker is distorted. I've tried resetting the NVRAM and SMC still nothing. I've Tried plugging in the headphones and its the same issue, its distorted on the left earphone. Tried changing frequency in the Midi Setup still and the issue still persists. The Startup sound is distorted also. At first i Had OS sierra installed when the issue occurred, I tried updating to High Sierra and still nothing. My current OS is Mojave.
Update (09/27/2018)
*Update* - now both speakers on the mac make the crackling sound like the volume is maxed out. However, on the headphones it’s only on the left side. I’m really out of ideas now.. Did a hardware check pressing “D” while booting up and it says that there is no issue. i’m at a total lost here
1 Comment
Did you try a USB DAC adapter to see if it was a clean signal there?
by
Add a comment
Most Helpful Answer
Did you have a liquid spill at one pointer sit the system down on a wet surface?
Why I ask is its very odd to have one channel have an issue if the DAC its self was having an issue.
I suspect the analog side of the connection has some corrosion which is shorting to ground enough to cause distortion issue.
You might also want to try a second system with the same data source or a USB DAC unit to see if the issue is the system or the recording.
Score 1
1 Comment:
Hi, No liquid spilled at any time on my Laptop. where i live a MacBook pro is close to $20,000 so liquids don't go near it. Also I'm looking into getting some bluetooth speakers to see if i will get the same issue. The only thing i've tried so far is headphones, and speakers that connect through the headphone port.
by
Add a comment
It might be a hardware issue too..if you hear music at a loud volume subwoofers sometimes crack, causing distortion. To be on the safe side before getting mad looking for deeper troubles or software issues I’d remove the loudspeaker and give it a thorough check with good light and some magnifying.
Score 1
2 Comments:
the sound is cracking on the headphones too. So I'm not sure if its the speaker.
by
@jiographic You're right, if that's the case forget about the speaker.
by
Add a comment
Add your answer
jiovany will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 3,212
