iPhone 3G No sound after I have replaced the back,
Right here goes.....
I have looked everywhere for this answer but cannot come up with anything,
I took my 8 GB iPhone apart to change the digitizer and back housing,
Everything went perfect all screws in the correct place everything,
I only have 2 minor problems,
1. I have a little metal clip leftover, it's smaller than the one for the camera.
2. When I assembled my iPhone all worked fine apart from the sound, I can use the earpiece fine to ring people the mic works, vibrate and when I have headphones in the sound works, it charges, But will not show any life with sound,
I am wondering if someone could tell me 1, where the little clip goes(this could fix the problem) or 2, tell me how to sort this out, if I have to buy a new speaker assembly that's ok but I just want to know why it wont work!
Thanks for reading
8 Comments
Yes I have the camera bit, that's all clipped in ok. About this mute button clip, where does that actually go? Because the button itself works which I can go from mute to loud, all connectors are in properly, do you know of any pictures of this part of the assembly?
by DavidThomas
Just being curious but were there 2 small pads on your volume bar? I'm going to find a flex to take a photo..
by pollytintop
Two small pads? If there were they were attached to the bar and didn't cone off so I just put the whole thing back in
by DavidThomas
I can't get my photo to upload... I think if you are missing this small piece which fits under the volume up end of that flex retainer, and also has a hole to keep to bottom of rear case, you may have the volume permanently on up. Does that make sense? You need to take the volume flex off, put the piece in and reassemble. The other alternative would be to remove or loosen the screw just at vol up end and see if that helps. Meanwhile I'll try to upload the photo of the piece I mean....
by pollytintop
Ok I will try, and would really appreciate a picture if you could, as I now have no reference as to where it actually goes,
by DavidThomas
Show 3 more comments
