Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
Replaced Battery, % Now Inconsistent, Coconut Batt says "Failure- yes"
I replaced the swollen OEM battery in my MBP 2012 with one from ifixit. However, since doing so, the few times I’ve had to use it away from a power source, the battery percentage drops immediately from 100% to 94% and then falls quickly until the MBP goes into hibernation at around 40% - I might get slightly over 2 hours use out of it.
I’ve tried the SMC reset listed here: https://ifixit-eu-en.helpscoutdocs.com/a.... No joy.
I’ve installed and run Coconut Battery, which says “Battery Failure - Yes” amongst other things (I will try to attach the screenshot)
Is there anything I can do? Or do I have a dud battery and need to replace it again?
Thanks,
David
Update (09/21/2018)
Coconut battery screenshot:
Add a comment
1 Answer
Chosen Solution
You’ll need to get a replacement battery. There appears to be a problem with it. Look at your paperwork for the return instructions.
Score 1
1 Comment:
Thank you - I will do that!
by
Add a comment
Add your answer
David Fardon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 171
