iPhone 7 Charging Issue
Hi All,
I have an iPhone 7 here which came in dead, even when connected to DCPS.
First I replaced Tristar, which at first appeared successful, charging current was 0.95 amps on 1 amp charger. It took some time for phone to power up due to battery being depleted. Once the phone turned on charging current dropped to 0.40 amps, the began to fluctuate and eventually it goes down to 0.01 amps. ( Replaced Tristar twice )
I then thought one of the MOFSETs beside Tristar may have moved causing a short so I proceeded to remove both and use jumpers for testing purposes. Again the results where the same.
Next I removed and reballed Trinity, again the results where the same.
Finally I replaced Tigris with a known good chip I borrowed from a donor board and again same senario.
I am really stumped at what this could be.
Any advice greatly appreciated.
Thanks!
