Announced in March 2015 and released April 10, 2015, the Galaxy S6 Edge is the curved-screen version of Samsung's newest flagship smartphone.
237 Questions View all
Samsung s6 edge suddenly charging slowly
My samsung s6 edge suddenly not having a fast cbarging capability and will take 5-6 hrs to be fully charged without use because if you use it the batt percentage goes down instead of going up
I change almost everything adaptor whatsoever
Nothing works
And heres the deal
I tried to put alcohol on my broken chord and put it inside my s6 edge to try to fix the issue or clean it with it then it works its not fast charge atleast i got 1 hr 30 something to full charge but heres the deal it always came ack after a bit of time and i need to repeat and repeat that again for me to be able to charge faster need help thanks
Add a comment
1 Answer
something nes like dirt on the pins inside the jack, if you have a compressed air can use it to blow out any dirt that might be inside the jack. If that doesn't work you might have to mod a charging cable with a bit of felt or similar soft material, moisten with rubbing alcohol and insert & remove it repeatedly to remove any drt from the pins.
As a side note, keep your pockets clean as that is usually how dirt would enter the jack in the first place.
2 Comments:
Sometimes the charger port needs to be replaced to fix this problem, something a reputable repair shop can do via soldering.
by
Thank you i'll try it now
by
Add a comment
Add your answer
Fixie will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 8
All Time: 1,123
