Sony's PlayStation TV entertainment system released in October 2014, model number VTE-1001.
10 Questions View all
My ps tv won’t connect to any controller I think my usb may be broken
I’ve had my pstv for about 3 years didn’t use it for about 6 months when I pulled it back out I tried connecting my controller to the back and it wouldn’t turn on my controller wasn’t connecting I tried others controllers same thing which leads me to believe its the USB port it may be damaged because nothing seems to connect/power on when I plug my usb in and just trying to see how I can fix it
Add a comment
Most Helpful Answer
Hi, I finally found a solution.
PROBLEM: my modded PSTV USB port was not giving any sign of life anymore. I tried every single method of connecting a PS3 or PS4 controller, nothing. The port was not charging controllers, so it seemed dead. Some threads pointed to insufficient power being the issue. I found my original PSTV power unit, but still that did not solve the problem. My PSTV being hacked, I did not want to got through the pain of resetting everything to factory standards and reinstalling everything.
SOLUTION: I connected a PS3 controller via Y-cable to a USB power unit and to the PSTV. It worked! Then I could also pair my PS4 controller. All set!
Score 1
1 Comment:
Is there a picture you have of your connection because I have the same problem. I fear the usb port might be damaged and I run my henkaku from a usb stick.
by
Add a comment
It might be just that.
but have you tried connecting a usb hub then your controller? if it doesn't work then, then its the usb port on your pstv
Add a comment
Add your answer
Sunny D will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 19
All Time: 1,235
