Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1525 Questions View all
Earpiece Volume Low even after replacing it
iPhone 6 Plus 64gb
Purchased December 2014. Yes, it is old but I have babied this phone.
All of a sudden the volume through the earpiece speaker became quite low.
The loud speakers were fine, no issues with them at all.
The volume was so low that I had to use earphones to speak.
I took the phone to Apple and they asked for AUD 210 to replace the earpiece without the guarantee that it would work. The speaker grill is clean and this was confirmed by Apple too.
I didn't think the money was worth it so I decided to replace it myself.
I ordered a new earpiece from eBay.
Replaced it by referring to the instruction from iFixit website.
The problem is still there even with the replacement earpiece.
I don't know why this is happening. Is the cable serving the earpiece faulty?
1 Comment
The issue fixed it self when I updated to iOS 12.
I do not how but it just fixed the issue.
by
Add a comment
1 Answer
Chosen Solution
If you follow the troubleshooting chain of command (if you will), it all starts with a dirty speaker grill. If it’s clean, then you move up to the actual ear speaker. Having tried that, the next step is the FCAM/Sensor flex as there could be an electrical issue with the flex. While you’re at it, check the condition of the connector on the logic board as well.
If none of that solves the problem, then you are probably facing a logic board issue which would require a micro-soldering repair.
Score 2
1 Comment:
Thank you for your response.
by
Add a comment
Add your answer
Abhishek will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 7,104
