PS4 doesn't respond to eject button and won't accept discs?
A few months back my son decided to put some quarters into the Blu-Ray drive of my PS4 and I took it apart and removed them and cleaned a little and it began working fine again. But he did it again a few weeks ago and when I put it back together after removing them this time the drive did not respond at all. The eject button no longer beeps when pressed regardless of whether or not there’s a disc in. It will not accept discs automatically, but it can be pushed in and the manual screw works to pull and push discs out. Once the disc is in the system doesn’t even try to read it as if it still doesn’t know there’s one there. I’ve opened it and checked for any obstructions or damaged cables multiple times but can’t see anything wrong. I play nearly everything on digital but I can’t update to the latest PS4 firmware (6.00) and according to the help desk it is because my drive is not working. My system is out of warranty so I’d really like to fix this. I have tried initializing my system both with and without the update and nothing gets the drive responding again.
2 Comments
If the optical drive was broken the button would still beep when pressed but the optical drive would not eject. This is odd, as there is no beep when pressing the eject button. I would suggest trying the optical drive in the not working PS4 on a working PS4 but that is ridiculous and I doubt anyone you know would let you crack theirs open and void their warranty just to test an optical drive. Let’s hope someone with more experience then me chimes in here...
by [deleted]
my ps4 eject button beeps when pushed but will not eject the disk, but it will take it though. What should I do? I'm thinking about getting it replaced.
by Donovan Sparks
