The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Questions View all
Large number of this model no longer turn on
With semester starting up I have had about ten of this model come into university service center with same issue:  Does not turn on!
Reset SMC, tried power on pads with keyboard as well as with the airport card, SSD module, LCD disconnected - still no help.
When under warranty I ordered replacement logic board and left I/O board which had fixed the unit in the past.
Now many are off warranty. Why are so many of these models failing?  Anyone else seeing a large number of this model with same issue?
Add a comment
1 Answer
Most Helpful Answer
Being in a university environment I’m sure these systems batteries are well used and given the age I think your issue is likely battery.
I would order a replacement battery for testing using a good known system disconnect its internal battery and plug in your test battery to charge it up. Then do the reverse with your dead systems using this battery. Are you able to get them to boot up?
You also may find the MacBook Pro 13" Retina (Late 2013-Early 2015) MagSafe 2 DC-In Board may need to be replaced.
I find this Apple T/N is useful in identifying many power type failures Apple Portables: Troubleshooting MagSafe adapters
MacBook Pro 13" Retina (Late 2013-Early 2015) MagSafe 2 DC-In Board Image
Product
$14.99
Score 1
Add a comment
Add your answer
Tom Morin will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 30
