Released in March 2017, the G6 is LG's flagship phone running Android 7.0. This device is available across all major wireless carriers. Physical repair of this device may eliminate water resistance and cause the device to be vulnerable to water damage.
Replace digitizer without LCD
I broke my front panel and I would like to replace it from the LCD. But all the guides I found were for replacing the LCD and the digitizer at the same time
Thank you in advance
Add a comment
1 Answer
Most Helpful Answer
The LCD is laminated together with the digitizer (touch screen layer) it isn’t something that you can separate easily and replace glass only without the proper machinery to do so.
You will need to replace the whole screen assembly. LCD and glass together as one piece.
LG G6 LCD Screen Replacement
LG G6 LCD and Digitizer
LG G6 Display Adhesive
Replace a front glass digitizer panel and LCD panel compatible with the LG G6 smartphone model #H871, #H870, #LS993, #H872, #VS998. Image
Product
$59.99
This custom cut adhesive film set secures the front glass digitizer screen and display to the front frame and bezel assembly of an LG G6 smartphone. Models H871, H870, LS993, H872, VS998. Image
Product
Score 3
Add a comment
Add your answer
Wassim D Ait Moussa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 194
