Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
1199 Questions View all
There’s a black “ink”spot in the bottom right corner of my screen?
My screen has no cracks on it, I’ve dropped it twice.
The first time it landed backside down and I noticed that a small black spot that sort of resembles ink appeared. I dropped it again today, it landed the same way, and the spot got bigger.
I can still control my screen directly on where the black spot is im just not sure what it is or how it could be repaired
Score 9
Add a comment
Chosen Solution
If you could post a picture, we could say for certain but it sounds to me like the actual OLED has been damaged. If that’s the case, then you will need to replace the screen.
If you want a high quality screen replacement, then Apple is still your best bet. However if your housing is damaged, they may refuse to replace the screen, in which case an independent repair shop will be able to replace the screen. Just ask about the quality level of the replacement screen because there are some inexpensive (relatively speaking) aftermarket LCD’s and now aftermarket and premium level OLED.
Score 9
9 Comments:
Hey does it spread all over after you dropped off ??
by
It's not spread ed it's just down at the last of the month
by
I just wanted to know what the plus was for at the end of the calendar
by
Nothing appears to be damaged it's just got a plus sign at the end of the calendar.
by
I don't believe anything is damaged if it is then the glass and back are a waste of mone
by
Show 4 more comments
Add a comment
Black splotches inside LCD display are caused by dropping the phone.
To get that fixed you would need to get the hole display replaced. Most expensive phone to get it replaced.
[linked product missing or disabled: IF377-003]
Score 6
4 Comments:
Does the warranty cover this type of damage?
by
Does it grow with time on iphoneX?
by
It can get worse over time as it bleeds like ink in a display that expands. This would not be covered under normal warranty as it is considered physical damage.
by
Is there a way to arrest it?
by
Add a comment
So I cracked my phone at the bottom right corner of my screen and it is showing vertical lines on that side of the phone can I get it fixed?
1 Comment:
You'll need to replace the display.
by
Add a comment
I think this will be helpful for you
https://okadtech.com/how-to-fix-black-sp...
You can try the solution to solve this problem.
I was facing this issue in my iphone x tried this article solution it didn’t work.
Tried the same solution in a others phone it worked.
Conclusion - If the pixel is dead then you can’t repair it but if it’s stucked then it can repaired.
I dropped my iphone x so maybe the pixels are broken so i unable to solve this problem. I have to replace my screen.
It all differ.
Add a comment
Add your answer
Xandria will be eternally grateful.
Past 24 Hours: 27
Past 7 Days: 200
Past 30 Days: 719
All Time: 207,282
