How to check if MacBook battery is FULLY working
I have MacBook Pro 15” Late 2013 which shut downs randomly (fully black background BUT display backlight on for couple seconds - then switch off completely).
I’ve done SMC NVRAM resets - clean (no apps) High Sierra - El Capitan installations - clean up inside everything with compressed air - no liquid damage (all white stickers - even under heatsink and LCD connector) - everything appear to work fine - just that random shutdowns.
Battery got 770 cycles and says status "normal”
I’ve watched few videos with Luis Rossman - many problems with MacBook can cause faulty battery - but mine LOOKS (but I do not know) working ok.
How to find out? I look for answer something like - take multimeter and when You have 100% charged and it shows on pins (which I don’t know which one) ie. 13.9V that means it is faulty - o something like that.
If I would have boot loop like here https://www.youtube.com/watch?v=h9S2_F7G...
Or Battery status: “replace now” - I would not have questions - I would replace it right away - but I don’t want to spend about £50 and risk damage MacBook removing it just to see it was not battery fault :(
Update (09/03/2018)
Here it is - I’ve got 3 those reports - almost the same
1 Comment
Often times your system will create a crash report when the OS dies so you'll need to go to the Console app and take a look at the System Reports to see what it has. Save it as a PDF and post it here for us to see.
by Dan
