replacement 60" tv screen
I am looking for a replacement screen for my 60â smart tv E601i-A3E
nichols3
replacement screens , specificly your TVâs size, are not commonly available. If you do find one it will most likely cost more than a new TV. Vizio uses a hodgepodge of LCD screen. To start your search you will have to remove the back of your TV and take a look at the panel itself. There should be a label afixed to it. Use the manufacturer and model number from that label to try an online search.
Your better chances would be to purchase a same model TV (fingers crossed that it uses teh same panel) but is broken other than the panel. Then harvest the LCD panel from that one. None of this will be easy and you will have to have patience.
Of course, you can always call Vizio and see if they are willing to help you out with that.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 292
