Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose Gold, Gold, Silver, Black, and Jet Black.
Changing NAND flash memory from IP6S to IP7
Hello
I’ve been looking at over 100 answers related to this question, and there’s a lot of different thoughts.
I have recieved a dead IP7. The NAND flash and capasitors around have burned quite good and it needs to be replaced. I have a lot of donor boards from IP6 and 6S but none for IP7. Can I take a NAND flash from 6S and solder on the IP7?
I have proper equipment, except PCIE NAND flash tool from china.
A lot of people say I need to flash the NAND chip. I’m just unsure if I need to do that in order to get the phone working. I don’t need any information stored in the memory.
What I’m thinking of is to replace the NAND and the phone should boot up in DFU mode, then I can wipe the phone and load in new OS and it should work. Am I correct?
Thanks in advance,
Martin
Add a comment
1 Answer
Chosen Solution
I don’t have an iPhone 6S/7 NAND programmer in the shop (yet!) but my understanding is that they are the same; they both use the same LGA70 NVMe NAND.
However, you can’t just replace the NAND without programming it. The phone will fail with error during restore.
Score 1
Add a comment
Add your answer
Martin Aleksander will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 1,859
