The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
MacBook Pro 13' (2015) not charging, not discharging when plugged in
My MBP is suddenly stopped charging but it does not discharge when it’s connected to the power adapter.
coconut battery is says there is nothing wrong with the battery and it doesn’t recognize that the power adapter is plugged in but it is not discharging either
I have tried SMC reset several times with no luck.
Add a comment
1 Answer
Most Helpful Answer
First inspect the MagSafe connections following this Apple T/N Apple Portables: Troubleshooting MagSafe adapters. Make sure your power adapter is in good shape and the MagSafe connector faces are also in good shape. Even still the switching MOSFET’s are likely in trouble here. One or more will need to be replaced on the logic board.
Score 1
Add a comment
Add your answer
Anesi Ikhianosime will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 175
