Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Long screw damage problem
Hi, i have same problem.the screw which i took from stand off hole cant be fitted again(the screw which is in top left)...so i assembled it without that screw..now itunes detects it and even show battery percentage but still black screen,receiving calls would vibrate with no sound,,silent/general toggle switch doesn't change state...pleases help
Update (08/29/2018)
There were no visible damage in motherboard...even the rubber casing on small components have not been removed...so i hope there were no damage in hardware externally...but when i look inside left bottom screw tracks are visible but they doesn't seem to be damaged...is this possibly be a long screw damage...because my iphone still receive calls ...only display and touchscreen is not working....im planing to swap display by this weak end and ill update status...so that anyone facing the symptoms will be helped....will a long screw damage will result in above symptoms?
Add a comment
1 Answer
Most Helpful Answer
Long screw damage iPhone 6 can break the LCM lines inside the board and cause no image.
You may have also caused a backlight failure when replacing the screen without disconnecting the battery first.
So assuming you tried with a known good screen that was tested working with a different device, you can conclude that you have board level failure. This board level failure can be backlight failure as well as long screw damage (most likely the latter). Or both if you are unlucky.
Score 2
Add a comment
Add your answer
m.ganesh Mvm will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 140
