Why my tv screen is showing rainbow colors but sound is fine
why my tv screen is showing rainbow colors but sound is fine panasonic viera 50”
Update (08/23/2018)
sound perfectly ok
sound perfectly ok
the lcd is damaged
can you attach an image of the “ rainbow” effect
then we can try navigate to a possible problem and solution
cheers
The problem started with a single thick line is the middle then extended all over the screen when touched it.Sound id fine though
kept on changing colors also
See image content:
It is just showing a rainbow colour stuff and the sound is ok then maybe like after an hour it will now show normal pic
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 28
All Time: 3,708
Hoo dang that's a RGB ink
The screen might have encountered a pressure damage
Which might be stuff thrown at it Or something
One section of the RGB got damaged and the ink kept on spreading
Will go through the entire screen in days
I'm sorry but there is no solution you can do unless you get a screen replacement
Cheers
by waris awe
