MacBook Pro A1502 does not power up!
A costumer of mine brings me a this Macbook Pro 13” late 2013 A1502, and told me that the MBP was working fine, and the the screen shuts-down, and that he could feel the inside fan working.
When I get the MBP the first thing I do was connect the MagSafe and the MBP powers up by it self, with 1% of battery charge.
Then, I start cheking everything in his MacOS and suddenly the screen went black, but the fan was working.
First thing I do: Reset PVRAM and SMC, the MBP continues to do the same thing (Powers Up OK, and while doing anything the screen goes black)
Then I remove the back lid and disconnect the battery, and the problem persist.
I leave the battery and the MagSafe connected for a while with the MBP off, hoping for the battery to charge a little more, but then, when I try to power it on again, it died, THE MBP DOES NOTHING, the MagSafe Led works fine(even when reseting SMC)
I remove the logic board and had a close look, it was a little contaminated so I clean it up.
The Macbook Pro stills DEAD, could I have some HELP here PLEASE!
Thank you!
2 Comments
i have one question
when it starts does it beep 3 times?
Thanks!
by Zander Castillon
it´s dead, it does nothing, and the logic board has voltage, I reset the SMC manually in the board and the led changes colors OK, but it does nothing. I also short the logic board in the power-up contacts but stills the same.
by Luis Anniel
