How to Replace broken tail light assembly
How do I replace the left rear tail light assembly on my 2013 Toyota Avalon Hybred
There should be some screws inside the trunk which hold the tail light assembly on. You’ll need a Torx bit to loosen / tighten the screws - I don’t know which size - go to an Auto parts store - they will let you try out different sizes till you find the correct one. Once you find the screws, it will be easy to remove / replace.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 105
