Movies, music, multimedia in your home. Use our guides to repair home entertainment devices from surround sound A/V receivers or conventional stereo receivers to power amplifiers, preamplifier, speakers, and iPod/Bluetooth speaker systems.
4608 Questions View all
SilverCrest KH2311 micro system Hi-Fi : no sound output.
I found a SilverCrest KH2311 micro system Hi-Fi, the issue is that there is no sound output from the two speakers, nor from a Headphone plugged into the mini jack connector. The device does switch on, the screen is fine. I try to listed the FM radio.
Note : When plugging the headphone in, I hear a “click” sound in the headphone speakers, so it seems it is powered, but that the issue is from some electronic part.
Note 2 : SilverCrest is a brand for electronics goods sold by the European markets brand Lild. The real manufacturer is certainly some chinese company, but i could not find a clone model.
Score 1
Add a comment
Most Helpful Answer
I would suspect the output amp IC as being defective. This is located under the silver heat sink at the rear of the unit. Remove the heat sink to see the part number which should be stamped on it. You may need to remove some heat sink compound as well. That would be my first guess.
Dan
Score 1
Add a comment
cosa fare per saperne il prezzo e come acquistarlo
Add a comment
Add your answer
David D. will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 338
