Televisions made by the Chinese multinational electronics company, TCL.
263 Questions View all
TV is automatically switching off after splash on inverter supply.
On inverter power supply tv is switching off after multiple splash.
Working fine on normal power supply.
Raised complaint with TV Manufaturer power supply of tv has been replaced but problem not resolved.
Complaint raised with inverter manufacturer but as per them inverter working fine.
Any solution please
Score 1
Add a comment
1 Answer
Most Helpful Answer
virendra saxena  so this does not sound like your TV is the issue. The issue here seems to be your power inverter. You need to let us know the make and model of the inverter and who checked it and how did they check it. You also want to know what you splashed on it. It is possible that you have a damaged control board. Use a multimeter and check the output of your inverter and connect a load on it and see if it continues to work or if it will shut down. I would suggest that you disassemble the inverter after testing and post some good pictures with your question, of what it looks like. That way we can see what you see. Adding images to an existing question
Score 1
Add a comment
Add your answer
virendra saxena will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 1,072
