Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
iPhone sleep/lock button getting stuck.
Hi, I was replacing the back cover on my iPhone 3g, everything was going well until i had to re-install the lock button. Every time I try to put it in, the button wont click and gets pushed down back into the phone. What am I doing wrong?
Edit: The button was working fine until I opened the phone.
Score -1
Add a comment
1 Answer
Chosen Solution
take a look at the guide on the right and just check that you have the silver metal loop hanging down towards the rear case, it sits on a little indentation on the rear case. If you over tighten the screws there is not enough "spring"in the button. It may be that you haven't got the 2 screws actually in the screw holes properly, it can be quite difficult to see where you are putting them.
Score 1
Add a comment
Add your answer
Tejas will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,278
