Released June 2009 / 2.53 GHz Core 2 Duo Processor
170 Questions View all
How do I repair my keyboard backlight?
Keyboard backlight hasn’t been working for a while - tried resetting etc. Where is / which is cable to check to make sure it is plugged in? May have happened when battery was replaced. Can’t seem to find the answer for this mac for this cable. Thanks.
Add a comment
1 Answer
Most Helpful Answer
The keyboard backlight connector can be seen in this IFIXIT guide: MacBook Pro 15" Unibody 2.53 GHz Mid 2009 Logic Board Replacement Jump down to Step22
Score 1
2 Comments:
Thanks. I checked that but it didn't seem to be the answer. I believe at this point I probably have to replace the whole backlight unit after 9 years of use.
by
Did you check the voltage with a DVM?
by
Add a comment
Add your answer
Mark Lynch will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 51
