Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
Putting to sleep with a magnet
On my 2015 MacBook Pro I could put the laptop display to sleep using a small, weak magnet on the left side of the case. I did this to use my external display as the only monitor.
I’m not sure if this still works on the 2016 with Touch Bar.
Add a comment
Chosen Solution
Here’s the location of the Hall sensor:
Score 1
2 Comments:
Hmm, where is that on the outside case?
by
@redkomrad - Right Side (click on the image for more detail)
by
Add a comment
Most Helpful Answer
Apple uses strong neodymium magnets, however, with your Mac booted .. even to the login screen … move the magnet (on a piece of paper towel so you don’t scratch the surface) around the outer top of the Top Case until you find the sensor location (i.e. until it goes to sleep) … it will work.
Score 1
Add a comment
On my MacBook Pro (15-inch, 2017), I needed two magnets - one on each side - to make it think the lid was closed.
I was able to do this by placing the magnets on the speaker grilles on each side, a little way down from the thunderbolt ports.
It seems likely they have added a second sensor to avoid the computer suspending by accident if you move a magnetic object close to it.
Score 1
Add a comment
Add your answer
Michael Minton will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 3,243
