Insects between glass and display
A tiny insect managed to crawl between the glass and display of my iMac 5k screen. I tried a vacuum cleaner on the air vents but it doesn’t come out. I Rather not try a canned air spray that might add more stuff into my mac. Off course this happened after the warranty ran out. Any tips on this?
2 Comments
The insect is the same i've seen a lot on my outside window frame this summer. So it must have gotten in somehow. Since i'm out of warranty, i have to be sure the glass supposed to be glued 100% airtight all around to the screen to make a case with apple support.
by TiNPiN
It's fully sealed all the way around with the gasket tape which is porous so air can move through (to adjust to air pressure).
You'll need a new screen if you did this on your own.
by Dan
