Why wont it turn on?
I've tried every button, but nothing will make it turn on. i need help!!!
I tried everything suggested but nothing helped.
Hunter it helps if you give more deatils. Plug it into a wall charger and see what happens. Also plug it into your computer and see if it recognized by itunes. Do a hard reset and see if it comes back on. Instructions from Apple
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
Good Luck and let us know how it is going
holding the Menu and Center worked for me... thanks oldturkey03
You're welcome ;-)
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,338
1 Comment
how much does it cost to have itunes fix it?
by Hunter
