Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Questions View all
iPhone 6S+ stuck at Apple logo after battery replace (needs restore).
I have a friend who's iPhone 6S+ phone had an aftermarket battery in it that's been working fine for well over a year and some change. Recently the battery started expanding. They kept using their phone, despite the expanding battery. The battery expanded to the point that it was pushing against the glass, which created a gap between the frame of the phone and the bezel of the screen assembly. The phone was used up until the point that the battery would no longer charge and the phone would no longer turn on. After replacing the battery on the phone with an original Apple battery, the phone remains at the Apple logo and won’t boot past that. I've seen on more than one occasion where a bad battery can cause a device to have to be factory reset, but it’s rare. Does anyone know why this might have happened? Regardless, I’m pretty sure the phone will have to be factory reset, but I’m trying to see if there are any other options to get the phone working before doing a factory reset. I also have reason to believe that the gap created between the screen, could have caused moisture to enter the phone.
Also… for the longest time, I’ve been trying to find PC program that’s capable of backing up a device in DFU mode, and haven’t found yet. Is it even possible to back up a device in DFU mode? I’m assuming this is not possible, because that means anyone could take any Apple device and enter it into DFU mode in an effort to retrieve/steal data from the phone.
Add a comment
Chosen Solution
I spent some hours researching this issue and came across this video after trying to update the phone via restore mode and received an error 26. Turns out that this video explains the issue very well.
https://www.youtube.com/watch?v=WUmY6TVS...
The video is very lengthy, but @12:30, the lady explains that using an iPhone with a bad battery; up until the point that the phone will no longer take charge, will cause data corruption. This is why the phone would not power on complete and was stuck in a boot loop. It was only up until I did a complete factory reset (last resort for me), that the phone restored and worked.
1 Comment:
How did you complete factory reset the phone
by
Add a comment
Most Helpful Answer
I wonder if the bad battery didn't cause an issue with the charge/power circuit. If you want to avoid restoring the device, then probing the main power circuitry (PMIC/TIGRIS/TRISTAR) would be a must. This gets into board level repair and troubleshooting so you may want to consider having this looked at by an experienced tech.
Score 1
Add a comment
If there's no physical damage (Minho is spot on there) one thing to try would be to get an Apple branded cord and block, and let this thing sit on it overnight. I know it sounds odd, but I've seen that 'revive' dead phones that had been fully charged down before and in various states of bizarre behavior because of it
1 Comment:
Other than the battery pressing against the screen, I didn’t see any physical damage or leaking from the battery. Will give your solution a try tonight.
by
Add a comment
I changed my batter in my phone and it's stuck on the apple logo how can I fix it with out a computer ?
Add a comment
Add your answer
uBreakIt iRepairIt will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 10
All Time: 2,929
