The LG 60LM6450 is a 60-inch LED television released in 2012. It supports 3D video with glasses at a resolution of 1920x1080 pixels.
77 Questions View all
Side button panel on my LG LCD
How do I fix the side button panel on my LG LCD? The button panel has been depressed to heavily and gotten stuck back or off track. Can I take the panel off and fix it? Or does it have to be replaced?
1 Comment:
@nateman100
verify for us that the TV is a LG 60LM6450.
by
Add a comment
1 Answer
Without seeing the damage, it will be difficult to state for sure, but sometimes, the plastic button "plate" just comes off of its supports. Sometimes the plastic posts that hold it in place break. Glue is your friend in these cases. Use a plastic glue . I prefer Plastic Weld by Plastruct. This is more of a solvent rather than a glue which means that the joint will be stronger.
If this is not the case, please open up the set and take (and post) a few pictures. That will help.
Dan
1 Comment:
Thanks Dan! I'll try it and let you know.
by
Add a comment
Add your answer
Charlie will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 33
