Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487 Questions View all
Samsung Galaxy S6 G9208 Midfram (Housing) antennas
Hello,
i'll appreciated if any one can tell me that what is function of Midfram (Housing) antennas, i have marked on attached picture, it have three antennas, top let, top right & bottom left,
please tell me each side antenna have what function,
Thanks.
Add a comment
1 Answer
Chosen Solution
Top left antenna is for Wi-Fi, top right is main cellular 4G / 3G.
Bottom left is GPS.
Score 4
4 Comments:
Thank Ben for quick reply, i got rip/broken top right antenna, so it mean 4G/3G will not work right? is there any way to fix this?
by
Yeah. You'll have to replace the midframe, note that the bottom two antenna cables that plug to logic board and dock connector flex are required for reception.
Try testing it, might just be little worse reception for 3g/4g.
by
i had test & 4G signal strength is -91dBm and it working all ok same like how it were before i guess!, so it mean my 3G/4G working ok or it will have bad reception of 3G/4G when i might be some where far from network tower,
should i really change Housing Mid-Frame of my phone or above results are ok?
by
I just ripped them by accident too but if reception appears to be okay just a little worse I would leave it at that.
by
Add a comment
Add your answer
The101 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 12
All Time: 1,410
