Screen touch slides on and off inoperative
i have 4th gen replaced screen, able to charge , screen comes on , unable to use touch screen slided to open and shut off???????
tom
tom
Tom,
Unfortunately that will happen from time to time. I always check operation before sticking the new digitizer glass especially on the 4th gen. You may not have gotten the digitizer plugged in correctly or it may have come unplugged during the rest of the assembly. You'll have to heat it up and remove the glass, (carefully) go through the rest of the steps (carefully)to remove the display and check the plug in the bottom of the logic board. Did you replace the copper tape wrap around the plug? Usually it is the other plug I have trouble with because of the short ribbon cable! As long as you didn't damage the logic board when you took it apart the first time you should be able to get it up and running again. Good luck and let us know how you progress.
Can you explain to me what exactly is going on? The touch screen doesn't work? What iPod is this??
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,246
5 Comments
i pod touch 4th gen. / when turned on, the slide bar to go to apps will not slide . when i touch the screen , it will not operate
by tom
tom, why did you replace the screen? Did it work before you replaced it? Anything else not working? Any recent firmware updates? Did you have a reliable supplier for your digitizer/screen?
by oldturkey03
reliable supplier ? found supplier from this sight.
replaced due to cracked screen at home button .
yes it worked before replacement, .
by tom
by Chris
i pod touch 4th gen. / when turned on, the slide bar to go to apps will not slide . when i touch the screen , it will not operate Submit
by tom
