Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose Gold, Gold, Silver, Black, and Jet Black.
Boot Loop after Screen Replacement
I installed a new genuine apple screen on my phone and it causes it to be stuck in a boot loop or take an extremely long time to boot. My old screen doesn't have this issue. I removed the home button and the camera flex cable and still does it. My question is can I transfer all the cables on the old broken screen to the new screen and have it work fine?
Thanks
Add a comment
1 Answer
Chosen Solution
Those flexes are embedded within the screen assembly, with the exception of the FCAM/Sensor flex. Just to be certain I understood your issue properly, you say that the replacement screen causes the boot to take a long time but the original screen doesn't. However, have you tried re-installing the original screen after the repair attempt with the replacement screen? If so, then that would point to a faulty replacement screen.
If you haven't re-installed the original screen after the repair, then that would be the first thing to try to help eliminate some variables.
Score 2
Add a comment
Add your answer
dailyshane1234 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 273
